my car is leaking most of the antifreeze When I drove into the pkg lot I noticed smoke coming out of the grill. About two hours later about a half a gallon of antifreeze leaked out the fluid was under the front end of the car where the radiator is? I filled it back up and this morning again fluid underneath the car. I do not know if it is all of the antifreeze b/c I have not tried to put more in, just got home from work? The men at churh say it is the thermoatat and as a result the coolant is leaking out due to overflow? Can you help me to know what the problem maybe. It is not really over heating the temp gage went up twice four days ago and both times I immediately shut the engine off and when I started it up five minutes later it stayed in the middle where it was suppose to be. Then I find out very low on antifreeze I filled it up and this lasted four days now not even lasting two hours?
Nov 20, 2008 at 5:12 PM
