1993 Acura Legend
1993 ACURA LEGEND
JERMAINE37
Engine Mechanical problem
1993 Acura Legend 6 cyl Two Wheel Drive Automatic
i need to know the name of switch that is on the block in wich the manifold sits on that tells water or coolant flow of the motor
Jul 20, 2009 at 9:41 AM
KHLOW2008
  • 41,814 POSTS
Hi jermaine37,
Components of the cooling system are:
1. Engine Coolant Sensor ( ECT)
2. Temperature sending unit
3. Thermostat.
4. Fan switch
I am not sure which item you are refering to. If you tell me the reason why you are looking for it, I might be able to provide the correct name.
Jul 23, 2009 at 12:13 PM
