I have a 92 Acura Legend 5-spd. The clutch works fine, all the gears engage fine, but once you are driving above 10mph and you hit the clutch to change gears, the front tires lock up completely. When the car comes to a stop, you can just drive off again until it is time to change gears. I do have some throw out bearing noise, but I wasn't sure if that could cause this severe of a problem. Just to clarify, when the clutch is pressed at speed the tires lock up completely until the car comes to a stop, then it is fine again.
Aug 18, 2009 at 4:36 AM
