I changed my upper and lower control arms, lower ball joints, sway bay linkage, and my struts a year ago, and when I turn or put weight on the front end I hear a squeaking noise liken rubber rubbing together. I did not put lube or grease on anything when I installed, but at the time I did not know I had to. Do you think that could be the problem. Or is it my rack and pinion going bad.
May 16, 2010 at 5:51 PM
