1992 Acura Legend how to replace alternator 92 legend
1992 ACURA LEGEND
200,000 MILES • 6 CYL • FWD • AUTOMATIC
SARGON
how to replace alternator 92 legend.. It's at the bottom below the battery
Jun 5, 2009 at 6:01 PM
Hey Sargon,
Disconnect battery cables. Remove battery and battery tray. Remove lower alternator mounting bolt and adjusting rod assembly. Remove alternator from mounting bracket to access wiring on back of alternator. Disconnect wiring harness connector and Black wire from alternator. Remove alternator. To install, reverse removal procedure.
Here is a guide that will help you as well
https://www.2carpros.com/articles/how-to-replace-an-alternator
Please let us know what you find so it will help others.
Best, Ken
Nov 28, 2016 at 10:48 AM
