Hey Sargon,
Disconnect battery cables. Remove battery and battery tray. Remove lower alternator mounting bolt and adjusting rod assembly. Remove alternator from mounting bracket to access wiring on back of alternator. Disconnect wiring harness connector and Black wire from alternator. Remove alternator. To install, reverse removal procedure.
Here is a guide that will help you as well
https://www.2carpros.com/articles/how-to-replace-an-alternator
Please let us know what you find so it will help others.
Best, Ken
Nov 28, 2016 at 10:48 AM
