Six cylinder two wheel drive automatic 190,000 miles
I changed the timing belt, water pump, and oil pump in my car, got the car to build up oil pressure, tried to start it then all it would do was turn over but never crank. Noticed that when I tried to get it in position to tow, when I pressed the brake pedal with the ignition switch, switched to on, the gear shift selector would not move, only when I would turn the key to almost start it could I be able to press the brake pedal and only then the gear shift would move from park to neutral. Do this sound like a neutral safety switch problem or a brake switch problem?
Apr 10, 2008 at 12:17 AM
