1991 Acura Legend timing belt/water pump replacement
1991 ACURA LEGEND
21,000 MILES • 6 CYL • FWD • AUTOMATIC
AELLIS31
I wanted to know if I could get an estimate of the total cost that it would take to replace the timing belt and the water pump at the same time in my vehicle. She is pushing over 210,000 miles now and it needs to be replaced very shortly. Thank you for your help!
Feb 1, 2010 at 2:23 PM
KHLOW2008
  • 41,814 POSTS
Hi aellis31
The labor time for replacement of the water pump, timing belt and related parts is listed at 6.3 hours. Oil seals and tensioner replacement is another 0.8 hr. You have to multiply it with your local rates.
$ 61.49 = Timing belt
$ 87.47 = Timing belt tensioner
$ 12.88 = Camshaft oil seal X 4
$ 12.88 = Crankshaft oil seal
$ 260.50 = Water pump
Above are OEM listed parts and if after market parts are used, they should be much lower in cost.
Feb 2, 2010 at 8:13 AM
