1991 Acura Legend speedometer
1991 ACURA LEGEND
195,000 MILES • 6 CYL • 2WD • AUTOMATIC
ADAMGARLOW
My speedometer jumps around or does not work. Mainly happens on the freeway. All of a sudden my speedometer will jump back and forth from around 120mph to 0. Sometimes the RPM's will be affected and the car will jolt. Any recommendations?
May 14, 2010 at 12:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
speedo is controlled by vehicle speed sensor and the VSS also interacts with the RPMs and tranny. if you are having issues with speedo and tach then the VSS will need inspected. make sure wiring is good to it and check ground to speed sensor, should be next to throttle body.
May 14, 2010 at 11:56 PM
