Does running only water w/o anti-freeze cause it to boil in the radiator and evaporate like in a tea kettle ? I replaced the thermostat and filled up with only water to make sure that was the problem so I wouldn't have to waiste new coolant dumping it out again. I drive the car it's fine temp wise, but the next morning I'll see I've lost water. There aren't any leaks and the car doesn't run hot anymore. I just want to make sure the water is evaporating before I dump it and fill up with the proper new coolant before it gets really cold.
Dec 22, 2008 at 1:42 AM
