Ignition Timing.....
ACURA INTEGRA
INTEGRA94
I have a 1994 Acura Integra LS with a B18B engine and I just got the clutch replaced.....but for no reason the mechanic doing the work removed the distributor causing my car to lose its Ignition timing...... yes the car will crank but wont start.....How will i be able to set the timing back up??????? :| Thanks
Oct 22, 2007 at 10:30 AM
BMRFIXIT
  • 19,053 POSTS
[quote:1f0bcfc2a8="Integra94"]I have a 1994 Acura Integra LS with a B18B engine and I just got the clutch replaced.....but for no reason the mechanic doing the work removed the distributor causing my car to lose its Ignition timing...... yes the car will crank but wont start.....How will i be able to set the timing back up??????? :| Thanks[/quote:1f0bcfc2a8]
find the timing marks on the front of the engine timing cover and the crank pully
set it to TDC the dist should be @ or close to #1 wire
also
the lugs on the end of the dist and it matind grove in the camshaft are both offset thats eliminate the possibility of 180 out of time
at the end chech and make sure you have spark
and the firing order in place (1 3 4 2 )
before wrong timing
good luck
Oct 23, 2007 at 8:05 AM
