Hub/Nut Bolt Removal
ACURA INTEGRA
MJUN
I have a 94 Integra and am having trouble trying to remove the hub/nut bolt I tried to take it off with a breaker bar and the right hub/nut socket but it just wouldnt budge and I ended up bending the breaker bar. I did not remove the tire or raise the car while I did this which is the way its suposed to be done but I just couldnt take it off. Could you give me some tips as to how I can easily remove the hub/nut bolt. Thank you.
Oct 2, 2007 at 8:01 AM
BRUCE HUNT
  • 3,754 POSTS
Are you referring to the axle nut on the CV axle? If so, you need to knock the lock back with a chisel.
Oct 2, 2007 at 2:10 PM
