this is still in regards to my car leaking coolant...from your previous response...you said to check all the hoses and make sure everything is tight...i did that and i actually found the source to the leak...but i'm just not sure if its it or not...as far as i see...its leaking from the intake manifold...so i'm thinking its the gasket....i have a Hondata intake manifold gasket and its showing some cracks on the outer parts of the gasket....could that be the cause? i know coolant flows throw a hole in the intake manifold also...if i change the gasket to a regular gasket...do you think it will fix the problem? thankfully...the engine does not overheat or anything like that...its temp is normal as it should be...all it does is leak and i have to fill up the radiator every 3 days or so....thanks
Oct 27, 2008 at 1:35 AM
