i have a 2001 integra...just recently..i heard a knocking noise coming from my driver side wheel...knowing a little about cars....i first thought it was the wheel bearing...so i had a new one pressed in the hub....still had the knock...so i then thought i was my axle...so it was replaced...still the same knock..no change...i double checked everything...bolts are locked tight..everything seems pretty much in place...my car is lowered...about 3 inches...wheel bearing is brand new...axle is brand new...i can feel the knock through the steering wheel at low speeds...it feels like its rolling over small bumps...after higher speeds it goes away...any help?? thanks!!
Sep 7, 2008 at 1:42 AM
