2001 Acura Integra driver side knocking
2001 ACURA INTEGRA
160,000 MILES • 4 CYL • FWD • MANUAL
JAPOSTOL78
  • 14 POSTS
i have a 2001 integra...just recently..i heard a knocking noise coming from my driver side wheel...knowing a little about cars....i first thought it was the wheel bearing...so i had a new one pressed in the hub....still had the knock...so i then thought i was my axle...so it was replaced...still the same knock..no change...i double checked everything...bolts are locked tight..everything seems pretty much in place...my car is lowered...about 3 inches...wheel bearing is brand new...axle is brand new...i can feel the knock through the steering wheel at low speeds...it feels like its rolling over small bumps...after higher speeds it goes away...any help?? thanks!!
Sep 7, 2008 at 1:42 AM
KHLOW2008
  • 41,814 POSTS
Hi japostol78,
Check the steering linkages, stabilizer bushes and end links and steering box free play.
Sep 7, 2008 at 2:20 AM
JAPOSTOL78
  • 14 POSTS
thanks for the reply....i rechecked everything...i actually replaced all my boots with energy suspension boots....knocking is gone....some shaking though...thinking it may be my shocks...car is lowered so it may have worn it out...
Sep 14, 2008 at 3:28 AM
