2001 Acura Integra 2001 Acura Integra water in hatch
2001 ACURA INTEGRA
103,000 MILES • 4 CYL • 2WD • AUTOMATIC
CAITICA86
Hi, I have noticed that whenever I drive in the rain, a significant amount of water builds up in the bottom of the hatch where the spare tire is. It is a problem because the car starts to smell funky and the windows fog up until I can pull out the shop vac and get the water out.
I have explored every possible option I can think of to explain this, but I cannot figure out why this happens. The water is not leaking from the hatch door, or from above the carpeting, because there are no visible leaks and nothing else gets wet. I checked the wheel wells but there aren't any holes. I thought it could be coming in from under the spare tire bracket, so I cauked it with silicone, but the water reappeared the next time I drove in the rain. Can anyone tell me what might be happening?
Feb 14, 2010 at 10:41 PM
KHLOW2008
  • 41,814 POSTS
Hi caitica86,
If equipped with sun roof, check if the drain hose is dislodged from its seat at base.
Use a garden hose to simulate the rain to test for leakages, it could be coming from the taillights due to improper sealing.
Feb 18, 2010 at 12:13 PM
