if the other car was sparking or smoking.. (zapping)
then the cables werent on correctly.
please notice not all positive are on the right and negative terminals are on the left. you have to make sure it is + or - dont just shove the jumper cables on just because you hookd left to left and right to right or right to GROUND.
hopefully you just tried the wrong polarity and it was sparkin off a bit to let you know.
if all your fuses under your hood, and under neath the dash is all fine and not burnt. then you are 100% ok and if you have a couple burnt fuses then its because of the polarity being attached.
lastly if car still doesnt start, try bring your dead battery to a autopart shop and have them test/charge it for you.
if that battery is extremelyyyyyy dead, then chances are most of the chemical inside the battery has already crystalized. meaning your battery is no longer good, even if you try to recharge it .. its not going to hold
try buying a new battery and cleaning terminals see if that'll work. if not then id remove the alternator and starter and have a autoshop test it for free.
Jun 6, 2010 at 6:30 PM
