hi, I just recently upgraded my stock cat converter out for a Aftermarket Performance cat converter.
the stock cat converter has 2 oxygen sensor as oppose to my new cat which has only 2 also but the problem is only 1 of the oxygen sensor reaches (the before cat).
the after cat oxygen sensor cannot reach the second bung/hole.. do i upgrade to a longer length O2 sensor or can i just run the car on 1 O2 sensor?
iam only using the "Front" or Before Cat Convert sensor only as of the moment.. can this be harmful to the car? and does it have any negative side effect?
Thanks- A BunCH!!!
Thanks- A BunCH!!!
Mar 28, 2009 at 6:30 PM
