got a 99 integra gsr, the temp sits just below the middle, only a little bit tho, so i changed the thermostat. found out that it was at the right temp, that is where gsr's temprature is suppose to be, well while doing this i realized my fans never run. used my multimeter and found out the wire leading to the fan switch gets 12v so i jumped the wires and the fans ran. so you would think it has to be the fan switch right? i found out i was wrong, i put a new one on(cant get down there to do continuity test) and it did not fix the problem. took that one back and tried a new one, also still nothing. so i went to a junk yard and bought a wire to connect to it(25 cents) and spliced the wire, hooked it and did continuity test, needless to say nothing. so why is my brand new fan switch not getting hot enought to turn fans on. again brand new thermostat and radiator(got hole in it) the car could sit for an hour and not run fans(never tried figure of speech) is it maybe just because its cold out. hopefully you can help no one else even tries because i have done all the things they would suggest.
Jan 31, 2009 at 7:46 PM
