1998 Acura Integra rough Idle Check Engine Light Engine Mis
1998 ACURA INTEGRA
215,000 MILES • 4 CYL • 2WD • MANUAL
BOBJONES07065
1998 Acura Integra. Few months ago, while driving, check engine light starting flashing and car was driving very rough. Mechanic replaced all spark plugs, according to code. Since replace, car has rough idle and uneven acceleration when accelerating hard. Car drives fine. Today, I turned the AC unit on and check engine light came back on (but not flashing). Code is Misfire Plug 1. Any advice?
Apr 25, 2009 at 3:44 PM
F4I_GUY
  • 3,302 POSTS
He should of done a full tune-up. Including plug wires, cap, rotor and filters (air/fuel).
If that doesn't cure the problem, it is either the injector to cylinder #1 or the compression of that cylinder that is causing the misfire.
Apr 25, 2009 at 7:19 PM
