1998 Acura Integra Grinding noise
1998 ACURA INTEGRA
80,000 MILES • 4 CYL • 2WD • MANUAL
WRATHOFCHONG
I am hearing a grinding noise that seems to be coming from underneath my car and not from either side ( not from wheel well). This noise seems to come and go but seems to happen more frequently the longer I drive my car. I had the brake pads replace less than 1000 miles ago and I am not sure what is causing the problem. I have stop using my car until I can figure out what is causing the problem.
Apr 21, 2008 at 4:43 PM
BRUCE HUNT
  • 3,754 POSTS
I assume the grinding noise comes when the vehicle is in motion. Have you considered that a wheel bearing most likely a rear one is going out?
Apr 22, 2008 at 11:30 AM
