1998 Acura Integra gas pedal a little bit Hard to press in
1998 ACURA INTEGRA
142,000 MILES • 4 CYL • 2WD • MANUAL
BUSSIE
  • 42 POSTS
My gas pedal hard to press in ,at low speed or when I start .When I am at low rpm and I press in the gas ,I have a feeling of the gas pedal be locked .It look like a click I think .I have need to press more hard in the gas pedal the gas coming a lot ,my head hit the seat. When I press in gas pedal on maximum and I shift the gear 6000 rpm like racing , no pedal gaz problem.
When the engine was cold the rpm bouncing up and down.
Jun 3, 2009 at 1:54 AM
ZACKMAN
  • 4,202 POSTS
Look at your throttle cable from the pedal all the way to the throttle body. Look for kinks or frayed cable. Similarly, check your cruise control cable. Also, check your throttle body itself. Make sure that you don't have any carbon build up that may cause the throttle body to "stick".
Jun 3, 2009 at 2:17 AM
BUSSIE
  • 42 POSTS
I clean the carbon in the throttle body behind the metal puck .and the gas pedal now was good.thank.
I have a other question: my idlle got 1000rpm when I stop to press in the gas pedal, when the car was stop rolling the rpm get down at 700rpm . Waht is that
Jun 8, 2009 at 9:02 PM
