1998 Acura Integra bumping sounds without shock faillure
1998 ACURA INTEGRA
BUSSIE
  • 42 POSTS
Suspension problem
1998 Acura Integra 4 cyl Front Wheel Drive Manual
after losing the right front wheel of my car I change the shock for imported Japan shock original, because the shock touch the Spindle. the front lowering of an inch since the change of the shock I think. I change the spindel , lower control arm, upper ball joint. I even change the stabilizing bar. I always have the same problem. suspention is hard as metal, with small bump in the street his made a sound like bang !!!! The car breaststroke as a earthquake. I'm shaking, all without make a jump.
Feb 12, 2009 at 4:11 AM
F4I_GUY
  • 3,302 POSTS
You are saying that the front lowered an inch?
Did you replace the coil spring as well? I would recommend OE front coil springs and shock dampeners. I'm not a fan of importing struts. Were they used?
What exactly are you hearing? When does the front end make a noise?
Feb 12, 2009 at 5:17 PM
BUSSIE
  • 42 POSTS
Yes I saying that the front lowered an inch
yes I Did replace the coil spring as well all part of the shock absorber .yes they are used .taken from a acura integra type R 1994-2001 ,in japan .So the suspention look like a new.
.The sound and sensation is the same even if I changing a lot part of the suspention . The suspention is very, very hard, I feel the bumps on the street like a motocross track. To the sound , imagine that you just do a jump on a motocross track ..BANG !!!
Mar 1, 2009 at 4:13 AM
F4I_GUY
  • 3,302 POSTS
Your sound, may be the coil spring. Ensure it is sitting on the perch properly, and that it is not broken. Sometimes a cracked spring is hard to find, so take a real good look.
You are feeling the bumps in the road because the strut is a lot stiffer than your OE strut which means you will be feeling a lot more bumps now.
Mar 1, 2009 at 2:12 PM
