1997 Acura Integra my car jolts when i drive
1997 ACURA INTEGRA
80,000 MILES • 4 CYL • 2WD • MANUAL
DIRTYAL89
when i drive my car jolts every once in a while and while doing so the rpm gauge starts to flicker. when i started it up today it didnt start up very well and started to jolt and flutter.
Sep 10, 2009 at 12:23 PM
F4I_GUY
  • 3,302 POSTS
Check TPS (throttle position sensor) function
Idle Air Control Valve operation
Throttle cable
And if it's manual, make sure the clutch is not grabbing while under load.
Sep 12, 2009 at 2:43 PM
DIRTYAL89
yea my car started doing it all the time now. it just constantly lugs while driving and the rpm gauge flickers. the check engine light isnt on and the clutch engages fine. so im hoping its a sensor
Sep 12, 2009 at 3:24 PM
MIKE66025
[quote:8b50aef7f3="dirtyal89"]when i drive my car jolts every once in a while and while doing so the rpm gauge starts to flicker. when i started it up today it didnt start up very well and started to jolt and flutter.[/quote:8b50aef7f3]
Did you ever get this issue with your car repaired? Can you please share what the problem was?
Thanks alot!!
Oct 22, 2009 at 3:49 PM
KHLOW2008
  • 41,814 POSTS
From the symptom description, I would suggest checking the ignition coil and Ignition Control Module.
Oct 23, 2009 at 7:35 AM
