Compressor turns on and off, will not blow cold air in hot weather. At night when it is cooler it will run like a champ, gets nice and cold and does not turn on and off causing the car to jerk at slow speeds. Also the pump gets blazing hot (doesn't glow but dropped a bit of water on it to see how hot, and sizzle...)
I checked belt backlash to make sure it is not loose, or too tight, its right on. I checked the freon and it was in the green, I used a do-it-yourself (by interdynamics) kit from advance auto. They informed me I could use this due in part that my car is equipped with a system compatible with 134a, they said it came stock in this model/year. (per their book)
My next (logical) step would be replace the compressor, I'm thinking the clutch is jacked, or maybe the electronics are back.
Any ideas?
Any ideas?
Jun 29, 2009 at 5:43 PM
