The car sat up for about 6 months. It worked fine when we parked it. Now neither the radiator or the condensor fans will turn on. Both fans work. I was able to jump them from the battery and they both work. The fuses are ok too. Someone told me to try the engine coolant temperature sensor. I removed the part and jumped it across the wire harness, and the fans turned on. I got the part from a salvage yard (actually got it from a friend who happened to have some extras after he changed his), but it didn't work. Is there anything else I can try? Should I attempt to get another part from a salvage yard on the off chance that the part I got was messed up? I have no idea where to go from here. Just want to get the car running so I can sell it.
Mar 7, 2010 at 1:40 PM
