1995 Acura Integra transmission grind
1995 ACURA INTEGRA
180,000 MILES • 4 CYL • FWD • MANUAL
TOUBEEVUE
every time when i get to 60 mph from 4th gear going to fith gear it grind. but normally when i drive from 30-50mph into fith gear it dont grind.what could be the cause.
Sep 18, 2008 at 4:23 PM
KHLOW2008
  • 41,814 POSTS
Hi toubeevue,
You mean the engaging of the 5th gear grinds when at higher speed only?
I would suggest checking the gear oil level and condition. When was the last time you replaced it? It could be a faulty 5th gear synchronizer ring gear and hub assy.
Sep 20, 2008 at 8:10 AM
