1995 Acura Integra Ignition coil
1995 ACURA INTEGRA
180,000 MILES • 4 CYL • FWD • MANUAL
THATONEKID48
I'm trying to replace my ignition coil, but the rotor is preventing me from removing the old ignition coil. How do I remove the rotor so I can take out the old coil, and put the new one in?
Jan 26, 2009 at 2:30 PM
F4I_GUY
  • 3,302 POSTS
if you look at the side that is facing the firewall you will see a little opening in that plastic black cover behind the rotor. You have to rotate the engine until the philips screw appears in that little opening.
Jan 28, 2009 at 5:35 PM
