1995 Acura Integra Acg fuse keeps blowing
1995 ACURA INTEGRA
150,000 MILES • 4 CYL • FWD • MANUAL
FRANKNELSON
My acg fuse keeps blowing in the car. It has an engine swap in it and the wiring harness is kinda jacked up. It was like that when I bought it. But I'm wondering if my alternator is bad or maybe if there is an open wire causing a short. Help!
Nov 6, 2010 at 7:58 PM
KHLOW2008
  • 41,814 POSTS
Hi Franknelson,
Thank you for the donation.
Is the fuse box similar to the one in the diagram?
Which numbered fuse is blowing?
Dose the fuse blow immediately upon replacing or does it blow intermittently?
Nov 7, 2010 at 1:49 AM
FRANKNELSON
I'm sorry but I don't see a diagram... It just shows little diamonds. But I know for a fact it is the acg fuses. According to my fuse panel it is the acg fuses. I have 2 of them. I can unplug the large wire in the fusebox under the hood going to the alternator and it'll start right up. It blows immediately after I turn the key on with new fuses installed when I have that large wire plugged up still. So I'm assuming it's an issue with the alternator or the wiring going to it...
Nov 7, 2010 at 10:48 AM
KHLOW2008
  • 41,814 POSTS
Sorry for the delay in responding. Somehow I did not receive any notification. Sorry for missing out on the diagram.
https://www.2carpros.com/forum/automotive_pictures/192750_FuseHood95IntegraFig02_1.jpg
I need to know the exact fuse so I can get the necessary information pertaining to the fuse.
Nov 11, 2010 at 7:01 AM
