1994 Acura Integra where is the coolant going?
1994 ACURA INTEGRA
B20CIVIC
Engine Cooling problem
1994 Acura Integra 4 cyl Front Wheel Drive Manual
My car is overheating and consuming coolant. No oil in coolant or coolant in oil. I did a. Compression test, 150 across all 4 cylinders. Head was checked ok. It's a sleeved race block . I also dis a carbon flora test... negative... any ideas?
Feb 6, 2010 at 4:22 PM
F4I_GUY
  • 3,302 POSTS
I assume the pressure test has not found any leaks?
Do you ever see coolant on the ground? You may need to put dye in the radiator and use a blacklight to help pinpoint the leak.
Check things such as your water pump, the water pump pipe at the back of the block, heater core, housings,etc.
Feb 7, 2010 at 7:19 PM
