Cruise control not working
1994 ACURA INTEGRA
DANE RHODE
My cruise control went out. Where is the solenoid, and or fuse?
Jan 24, 2009 at 10:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
There are two fuses, but I would check the fuses brake light switch and clock spring through the steering wheel which can break causing the cruise control not to work anymore. Here is a guide the the cruise control wiring diagrams to help you fix the problem:
Cheers
Jan 24, 2009 at 10:24 PM
GREGTHOS
I had this problem and had to replace the clock spring in the steering wheel cost me $260.00 at the shop. I wish I did it myself. FYI
Jul 19, 2018 at 2:44 PM
