1994 Acura Integra blinkers and hazard lights
1994 ACURA INTEGRA
210,000 MILES • 4 CYL • FWD • MANUAL
RONDA1994
On my 1994 acura integra the blinkers and hazard lights do not work or make any sound. We have change the relay under the dash but still nothing. We have a manual but it does not show a diagram of where the fuse is under the hood or the other switch is located so we can check it.
Jan 27, 2010 at 8:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you only have one relay for both the signals and the hazards. it is located under the left side of dash, left of the steering column. if it is OK then check fuse # 26 (10-amp) in the fuse block located behind a cover in the dash, to the left of steering column.
Jan 27, 2010 at 11:29 PM
