1994 Acura Integra abs system
1994 ACURA INTEGRA
240,000 MILES • 4 CYL • FWD • MANUAL
DANNYFALLIN
When im driving my car and im coming to a stop while pushing the brakes when im almost stopped the brake pedal jumps a little like it loses some brake pressure like air is in the lines but i bleed the brakes after flushing the system and bleed the abs system helps a little but starts back. what acan be the cause and if it is the abs sytem can i take it off and will the brakes still work
Sep 27, 2008 at 3:04 PM
KHLOW2008
  • 41,814 POSTS
Hi dannyfallin,
Is the ALB/ABS indicator light showing?
Did you check the brake calipers and wheel bearings?
When stopped, does the brake pedal sinks when the brake pedal is held depressed?
You can remove the ABS master pump but you need to install a proportioninig Controll valve.
Oct 2, 2008 at 2:27 PM
