Four cylinder front wheel drive manual 137,000 miles
once every couple weeks no start. Turn key hear audible click but starter will not spin. Battery new, starter new (replaced it twice to be sure), cables new, alternator working (12vdc engine off 4.2 vdc engine running). Replaced connector which leads from ignition to starter.
Weeks pass and same symptom occurs.
All that is left, I believe, is the main relay aka starter relay.
Could this relay be located somewhere under the dash, be the problem?
If so can you help me locate it? Acura parts describes it as three inches in length and four bolted under dash on drivers side. However a discount auto parts guy tells me no, no it is much smaller and held by one bolt through a bracket on the passenger side. help me please .saailer
Feb 6, 2009 at 2:59 PM
The starter relay could be the problem but we need to verify the problem.
1 Where is the clicking noise coming from? inside vehicle or from starter?
2. Did you try using a remote wire to crank the starter with direct power from battery?
It could be a faulty ignition switch that is failing and not providing sufficient contact and power draw to crank the starter.
