I just bought this car 4months ago and i just noticed that the cooling fans are wired differently and unprofessionally. There is one wire connecting the negative terminal on my battery and it leads to three other wires, two wires go to each fan. The other wire comes from what looks like my fog light plug. Then there is another wire coming from the fog lamp plug as well, which goes to three other wires. two go the each fan and the other goes to the fuse block under the dash board, driver side. one of the fans just stops working when i drive a long distance and spontaneously come on causing my engine to over heat. What do i do? Do i just re-wire what is there but more professionally because couldn't a bad connection cause this? Any suggestions will help. Thank You in advance.
Aug 15, 2009 at 7:13 PM
