1992 Acura Integra speedometer
1992 ACURA INTEGRA
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
THENNE
we had the water pump replaced in the Acura and the speedometer stopped working , i am not able to figure out if it was something that was happening in the past as we just purchased the car, or if it was something that happen when we replaced the water pump. can you give me some ideas before I start tearing it apart where I should look first.
May 25, 2010 at 12:13 AM
KHLOW2008
  • 41,814 POSTS
Hi Thenne,
Replacement of the water pump should not be related to the speedometer.
Check the Vehicle Speed Sensor located on top of transaxle housing below the thermostat housing.
May 25, 2010 at 8:23 AM
