1992 Acura Integra No fire to spark plugs
1992 ACURA INTEGRA
JAYMES91
Electrical problem
1992 Acura Integra 4 cyl Front Wheel Drive Automatic
we replaced coil and ignitor still no fire
Oct 6, 2009 at 7:20 PM
KHLOW2008
  • 41,814 POSTS
Hi jaymes91,
Was any repairs carried out prior to this happening?
Did you test the igniton coil power supply?
Is the Check Engine Light staying on after more than 2 seconds?
Oct 7, 2009 at 10:10 AM
JAYMES91
yes the volts read twelve and we also changed the igniter and the distibutor looks brand new actually and i just changed the rotor and cap and still nothing
Oct 7, 2009 at 5:50 PM
KHLOW2008
  • 41,814 POSTS
Is the 12 volts present at the Black/Yellow wire of distributor when ignition switch is turned ON and while cranlking?
Does the Check engine light stay ON or goes off after 2 seconds of turning ignition ON?
Did you check if the rotor is turning while cranking
? A bad timing belt would not turn the rotor and result in no sparks.
Oct 8, 2009 at 7:32 AM
JAYMES91
the rotor is turning and the belt is like 5 months old and still in good shape the black and yellow wire do have twelve volts going through it and all my instrument lights stay on
Oct 8, 2009 at 1:32 PM
KHLOW2008
  • 41,814 POSTS
Does the CHECK ENGINE LIGHT stay on when igniton is turned on?
Oct 8, 2009 at 2:06 PM
MAZDASPEED8057
hey i have this same problem and i would like to know y i am not gettin spark wen i should b gettin cus i am having 12volts goin to the distributor
Oct 16, 2009 at 8:07 PM
IMPORTEDMECHANIC
i have replaced my distrubtor brand new, checked my belt as well which is good also, i am a mechanic in school, my next step i am doing is replacing the ecu or pcm which stand for electronic control unit or power control module, which possiblity went out on my car so if that is the case i would get another ecu and try it, that what may be the problem. will update on that scenrio on monday evening, if that what fix my car. best way is to buy a used ecm off a junk car and take it to the dealership to have them program it. i heard it cost about 250.00 or so, but i would check with your local dealership if you want a brand new one and programmed you would be looking at about 900.00 for repair
Oct 17, 2009 at 5:40 PM
KHLOW2008
  • 41,814 POSTS
For 1992 models, no progrmming can be done nor required on ECU/PCM. Just get a ECU/PCM and plugit in and it should work.
I asked one question but did not receive any answer for it.
Does the CHECK Engine Light comes on when ignition switch is turned ON?
Does it goes OFF after 2 seconds ?
Both above answers MUST be yes.
Oct 17, 2009 at 5:47 PM
MAZDASPEED8057
yea the check engine light comes on and then goes out in 2 sec
Oct 17, 2009 at 11:49 PM
KHLOW2008
  • 41,814 POSTS
This question has diferent people having the same problem but the job done is different. Someone mentioned replacing the distributor and others did not, so it would be best if you list down what has been done so that we don't get confused.
Oct 17, 2009 at 11:55 PM
IMPORTEDMECHANIC
my car is up and running again, i replace my ecu and it works and fire according, no engine light came on, so i must have more wiring problem, but the answer to the turn over but no fire is to replace your ecu/pcm save yourself money as i learn the hard way...
Oct 21, 2009 at 11:03 PM
KHLOW2008
  • 41,814 POSTS
As I mentioned earlier, not all causes of problems are the same. What if the ignition coils is bad and you replaced the ECM and still does not have any sparks?
The problerm is that most people do not go into diagnostics and just try with replacement of this and that hoping to strike the jackpot and often is a costly affair.
Perform diagnostics to find out what is wrong before replacement of parts is the way to save $, time and unnecessary parts replacement, not to mention the inconveniences.
Oct 22, 2009 at 7:54 AM
