1992 Acura Integra installing an ignition switch
1992 ACURA INTEGRA
NIRVANAFAN92
Electrical problem
1992 Acura Integra Two Wheel Drive
so i got a 1992 acura integra from my dad who removed the ignition switch cuz he was pissed at my mom, and i nor my mom know how to put it back in. all the parts are there but again i dont know how to replace it =(
Mar 8, 2010 at 5:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you mean the part where the key inserts (ignition lock cylinder) or the actual switch ?
Mar 8, 2010 at 7:00 PM
NIRVANAFAN92
the key lock and all that goes to it
Mar 22, 2010 at 6:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL & INSTALLATION
Integra
1.Disconnect the negative battery cable.
2.Remove the dashboard lower panel, left knee bolster and left kick panel.
3.Remove the steering wheel. Remove the steering column covers.
4.Center punch each of the shear bolts and drill the heads off with a 3 / 16 in. drill bit. Be sure to be careful not to damage the switch body when removing the shear head.
5.Remove the shear bolts from the switch body.
To install:
6.Install the new ignition switch without the key inserted. Loosely tighten the new shear bolts. Make sure the projection of the ignition switch is aligned with the hole in the steering column.
7.Insert the ignition key and check for proper operation of the steering wheel lock and that the ignition key turns freely.
8.Tighten the shear bolts until the heads twist off.
Mar 22, 2010 at 6:20 PM
