1992 Acura Integra Idles low, stalls at stops
1992 ACURA INTEGRA
22,300 MILES • 4 CYL • FWD • AUTOMATIC
JENNDILLON2004
Engine idles low at stops and stalls at anything under 1500rpm. Jumpy chugging action when start out until reach at least 45mph. When let up on the gas the engine jumps instead of slowing down easily. I have recently replaced the alternator, had oil changed, new battery and replaced the spark plugs (not that I think any of that is related but thought important to note). Any help would be appreciated. Thank you.
Jan 19, 2010 at 12:51 PM
KHLOW2008
  • 41,814 POSTS
Hi jenndillon2004,
Were the spark plug wires and ignition coil checked?
Stalling at idling could be due to a mechanical fault with the engine. Get a compression test done to check the mechanical condition.
Jan 21, 2010 at 9:26 AM
