1991 Acura Integra no spark
1991 ACURA INTEGRA
210,000 MILES • 4 CYL • FWD • AUTOMATIC
GERDTSE
1991 Acura Integra. it start when it wants to. turnover but will not start. i changed the coil & spark plugs but i still get the dsame resaults
Jan 2, 2010 at 3:34 PM
No start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 2, 2010 at 3:39 PM
