My Acura integra makes a loud noise, sounds like it is coming from the tires or bushings, but i am not sure. I tried lifting the car off of its front wheels and started the car put it in first gear and steped on the gas, but it did not make any noise, but then I drove it and it made the noise almost like a belt but alot worse, and the belts are fine. It seems like it only makes the noise when the car is on the road maybe the pressure of the weight of the car is causing the noise please help. thank you I will make a donation when I can thankyou
Oct 23, 2008 at 1:13 AM
