1991 Acura Integra key in stops runnng
1991 ACURA INTEGRA
130,000 MILES • 4 CYL • 2WD • MANUAL
123GIVENJEFF
  • 6 POSTS
I was driving down the road when my car shut down so I touched the key and it started running again. what do I nead to replace to fix the problem. thanks Jeff.
Aug 27, 2009 at 3:56 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I feel that the ignition switch may be faulty, dose your key ring have a large number of keys on it? as this is often the cause of failing switches and locks, the extra weight over a long tome wears out the lock and the switch can move out of contact causing problems.
mark (mhpautos)
Aug 27, 2009 at 6:34 PM
