1991 Acura Integra Ignition and starter
1991 ACURA INTEGRA
179,000 MILES • 4 CYL • FWD • MANUAL
ROJOHNCAGANG
I replaced my starter on my 1991 integra so the car started alright. A couple days after it won't star. I'm thinking it's tha ignition wires and switch because a couple months before my car wouldn't start and so as we turn tha key smoke came out from the dash. When I turn the key the lights still turn on, it just feel like it's not connecting to the starter. Can you help me, if posible with diagrams too?
Sep 4, 2010 at 2:54 AM
KHLOW2008
  • 41,814 POSTS
Hi rojohncagang, Sorry I could not find any diagrams to show you. Begore removal, it would be better to test the switch as the starting part of the switch seldom fails. Removal & Installation (Integra) Disconnect negative battery cable. Remove steering wheel. Remove upper and lower steering column covers. Remove lower dashboard panel and left knee bolster. Disconnect ignition switch 7-pin connector from main wiring harness. Turn ignition key to "O" position. Remove 2 screws and ignition switch. To install, reverse removal procedure. From the diagram, use a test lamp to test for power supply from ignition switch ( Black/White wire) to starter relay.
https://www.2carpros.com/forum/automotive_pictures/192750_Starting91IntegraFig13a_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_Starting91IntegraFig13b_1.jpg
Sep 4, 2010 at 2:26 PM
