1990 Acura Integra cv axle assembly change
1990 ACURA INTEGRA
199,873 MILES • 4 CYL • 2WD • AUTOMATIC
RAV4RISHU
hi im just inquire if i need any extra parts to change my cv axle assembly
Jan 5, 2009 at 3:09 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will need to be able to re fill the transmission as you will loose the oil. and just make sure that you fit any new split pins that you remove, check the condition of the seals in the diff housing, replace these if there is any sign of leakage also if the front brakes are getting low its a good time to fit a new set of pads as well.
mark (mhpautos)
Jan 5, 2009 at 4:09 AM
