During cold start the idling speed should be above 1000 rpm and in your case it seems to be below that.
Replacing the fuel pump is not gong to help. The 2 possible causes are :
1. The idle control system is malfunctioning. It could be a faulty or clogged IAC and/or throttle body. If the Malfunction Indicator Light ( MIL) is not showing, it would most likely be clogging or a stuck IAC valve and this problem can be rectified by cleaning the throttle body and IAC.
2. Compression leak. This could be caused by valves or a bad head gasket. If it is a bad head gasket, it would normally be associated with coolant losses or overheating.
If it is valve leakages, a compression test should be able to show something. Chec the valve clearances to see if any are too tight.
Aug 5, 2009 at 8:23 AM
