sorry but where it is a Canadian model and I am U.S. based, I can't find any more details other than just replacement steps. Here are some more detailed steps to removing the door panel though, maybe it will help a bit more..It's the biggest part of the job, the actuator itself just disconnect the wiring harness then unbolt a few fasteners and it will come out.
"""There are screws securing that door panel. Two small philips screws behind the door handle - use a tiny flathead screwdriver to pry the cover plate off and get at them. Then open the door grip up using a panel popper (princess auto, canadian tire, costs like 8 bucks). There's a pair of philips screws there too, you have to reach in pretty deep to get them though. Then just grab the bottom edge of the plastic panel and pull outwards firmly. You'll hear the clips popping out one by one, till you get to the top, then you can lift the panel up and off the door.
Before you put the panel back, pull off the front sail panel triangle dealie (the one behind your side mirror mount, it's only held in with a single metal clip), THEN install the door panel. Then pop the sail panel triangle thing back on. """
Jan 28, 2010 at 5:50 PM
