2001 Acura CL Removal of change tray (on front dash)
2001 ACURA CL
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
The red cardboard velvet lined change tray is stuck open, probably coins shifted back and prevents it from closing properly.
How to remove tray to remove items blocking proper closure? No books on this model so I don't have any diagrams to help.
Mar 7, 2008 at 8:19 AM
JEREMIAH
  • 217 POSTS
it's a lengthy procedure for the inexperienced coz you are going to have to remove the whole bottom of the center console.
instead try to reach underneath it by removing the the cover for the dlc connector.right below the tray is a plastic door that easily pulls out.you should be able to fish out a few coins with your fingers and loosen the cover.
lif not,let me know and i can give you instructions on how to remove the center console.
Mar 7, 2008 at 4:25 PM
