Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Acura
CL
Engine
Symptoms
Revs Up
engine is at operating temperature the idle goes to 1500 RPMs?
1999 ACURA CL
133,000 MILES • 6 CYL • FWD • AUTOMATIC
VETTETOGO
MEMBER
1 POST
FOLLOW
When the engine is at operating temperature the idle goes to 1500 RPMs in neutral and fluctuates 500 RPMs in gear it seems to idle fine.
May 12, 2008 at 1:16 PM
CERTIFIED EXPERT
This can happen when the IAC valve needs service, here is the location so you can check it out with a guide to give you step by step instructions.
https://www.2carpros.com/articles/idle-air-control-valve-service
This will need to be removed and cleaned. Check out the images (below). Please let us know what happens.
Image (Click to enlarge)
Mar 21, 2024 at 5:29 PM
CERTIFIED EXPERT
anything?
May 11, 2024 at 12:48 PM
