1999 Acura CL EGR Valve and Intake Manifold
1999 ACURA CL
64,000 MILES • 6 CYL • 2WD • AUTOMATIC
MJOD321
My Check Engine Light is on and rec'd a P0401 OBDII code..
Is cleaning my EGR valve and intake manifold the best first step to take to clear the code?
I have a mechanic that works out of his garage, do you think he could fix it?
If not, what can I expect to pay the dealership/local repair shop for this cleaning?
Thank you
Nov 4, 2008 at 8:17 PM
DAVE H
  • 13,384 POSTS
yes you could just clean or even replace the egr valve ? to clear the code your mechanic would need a code reader ? if you clean the EGR valve and clear the fault codes test drive the vehicle and the codes don't re-occur then jobs done, if they do re-occur you will have to replace valve, clear codes and test drive again
Nov 6, 2008 at 10:04 AM
