1998 Acura CL shifting
1998 ACURA CL
145,000 MILES • 6 CYL • FWD • AUTOMATIC
DANTHEMAGICMAN
my acura recently got where it would not go into any forward gear. i jacked the car up and checked the shifter cable, finding it intact itook it loose from the shifter as i moved it the car went into gear. it does'nt slip in any gear but goes out of gear at the shift points when i let off the gas it goes from first to third gear skips second then out again from third untill i let off then it goes into forth and pulls fine untill i come to a stop where it goes out of gear untill i put it in neutral then back to drive
Aug 28, 2009 at 10:07 AM
CARLIFE65
  • 200 POSTS
it sound to me like you have internal transmission damage you can take it to a transmission shop, and they will test it for free
Oct 11, 2009 at 1:15 AM
